Icon Scrambler Oil Change
Discussion in 'Scrambler' started by Mark9, May 17, 2020.
  1. Just changed the oil on my Icon, I always change the oil at half the recommended service interval, I didn’t torque the oil drain plug to 42nm as the manual suggests!!!, that simply cannot be correct!, I just tightened it by feel and added a dob of Sicaflex (liquid wire lock:)) externally once tightened for peace of mind, anyway thought I’d post this warning, the manual is wrong.
  2. It's very obviously wrong, the drain plug only has a 5mm hex which will round out very easily. The first time I did my own oil change I thought it was going to round trying to get the bugger loose. I've replaced the drain plug with a hex head one that I've wire locked.
    Ditto for the Supersport.
