So would fitting a slipper clutch to a 996 make it lighter on the wrist? Already have a JHP clutch slave cylinder fitted which if I am honest doesn't make any difference on the wrist.... cheers
no not really…..the slipper bit doesn't/ isn't anything to do with the feel of the in/ out of the clutch
Oberon slave? You could try removing two of the springs from the pressure plate, although in some cases this causes slippage. Worth a go though...
Ok what size rcs ? I believe they are 16 but I read that some road clutches have heavier parts and need a bigger bore?? would the standard 16mm be good for the 996
Oberon slave cylinder , it made a huge difference and i still run all the springs .I did this after my first couple of "through town" rides . Top quality as well .
I had the 16x18 Brembo RCS and it was faultless, absolutely spot-on. It made the clutch a lot lighter, and gave more feel
