Hi Paul, You can get cheap discs spacers made here, Motorcycle and bicycle parts, accessories and clothing they laser cut ally to your sizes. I have the pcd etc for 1098 wheels, you need to find the thickness you need. I will ask my boy, Special Andy to make the axle spacers, if you can find the widths you need. Mick
I have seen on another forum the sizes, I just want to buy the kit rather than getting bits here and there
Stolen from 1299 forum... You need spacers that goes behind the brake disc that are 7,5mm each Then on the wheel axe the spacers size is: - for the "small one": 3,8 cm total (2,3cm for the part that is "outside" the wheel axe) - for the "long one": 4,7 cm total (3,2cm for the part that is "outside" the wheel axe")
