Sparks In The Right Place And Easy Start In The Bell Mouth But Just Won't Fire
Discussion in 'Technical Help' started by Widgercharlie, Jan 14, 2023.
  1. I am new on here Guys and Girls and others
    I have a 916 sp3 owned from new which I enjoyed for a while in the late 90s but got totally fed up with the reliability.
    I stored the bike for many years and 2 months ago decided to try and get her going.
    I have done all the service stuff and double checked. It's got fantastic compression (only done 3000 miles)
    Before I wanted to put the tank on I wanted to check she would start but only once did it bust into life so I know belts are OK and ignition is OK
    I have a great spark and using timing strobe can see its firing at TDC in the left hand cover window as stated in manual, no advance at idle
    I have never NOT started any of my British bikes using easy start but 916 not happy at all. It's almost like the spark is breaking down under compression but I would be surprised looking at the spark out of engine.
    Flat type plugs.
    Any suggestions would help
    Thanks Charlie
    #1 Widgercharlie, Jan 14, 2023
  2. Not quite clear but your trying to run without the tank on?
  3. Be careful of using ES don’t be too liberal with it as I once was, bike ended up on fire……..
    • WTF WTF x 1
  4. Does it fire at all with Easi Start? I'm not familiar with the SP3, what ECU does it use?
  5. Hello thanks for advice so far
    I will be careful with ES
    The ecu is I belive the P8
    It uses 2 pickups one for rpm on the flywheel and one on the large timing gear.
  6. With the P8 both pickups are the same. If you swap their connectors round it won't fire.. It's easy to check
  7. Thanks Derek,
    I don't think I would get a spark and she did fire up once.
    I am wondering if the fuel pump should be connected so ECU is getting a pressure signal
    It may be making the timing to retarded
  8. I’m still confused. Is the tank on or off? Are the injectors connected to a working fuel pump? Or are you cranking it whilst spraying ES into the throttle bodies?
  9. agree with the retarded bit, are you using Easy Start neat or does it get a chance to blend with a continuing "normal" supply of fuel? If it's the former then this is the reason and hence be careful as it might even try to run backwards. I use GT85 penetrating spray now when all I need is a witness "cough" because it's a lubricant for the bores but the propellant is also briefly flammable but not as volatile as Easy Start.
  10. Just to make sure it's all OK and waiting for the tank to come back after a small repair
  11. It will not run for long without the fuel tank and fuel pump connected
  12. I don’t think it will run, or even start, at all as there’ll be no pressure at the injectors even if there is a dribble of fuel in the lines.
  13. Hi no tank is not connected and injectors are not connected so I thought it would fire for a second using Easy Start ..I want to check its going to fire up when I do fit tank back, which I have also refurbished with new pump, filters and pipes
    I'm thinking the ECU maybe giving a false ignition timing, but the strobe shows spark at the tdc dots on the flywheel on both cylinders
  14. Hi yes I know but it'not firing at all
  15. but you have a spark? - as engine hasn't run for so long* I would give a couple of squirts of thin oil (we used to say 3 in1!) down each bore before cranking (if you haven't already) as not only could they be initially dry, but also rings might be a little "bound" due to* (or worse of course) plus the Easy Start (particularly if used excessively) can quickly wash away the little initial oil that is there/if it's there at all.
    Alternatively, you could just carry on assembling up and trust that it's fine - i think that's what I would do - you got one cough earlier on during assembly?
  16. Why not wait until you have a tank with pump and injectors all correctly connected?
    Then, if it still doesn’t start, let us know.
    As it is, without tank, injectors, pump, why does it matter?
  17. I agree with what Ricky says above, pop the tank back on, Connect the fuel pipes and pump electrics, make sure it’s fresh fuel in the tank, and enough of it, at least 5 litres, then try.
    Chris’ suggestion of light oil into each bore is good as well, especially if it’s been standing for many years.
  18. Thanks for all your help
    I will let you know how I get on
  19. Update on 916sp3
    It turned out to be the sparkplugs which are the original discharge type
    They have a very good spark out of the engine but will not fire when installed I fitter standard new standard plugs and she fired straight away
    Question is shall I buy the £70.00 + discharge plugs as was fitted originally
    I'm not thinking of racing the old girl nowadays.
    I'm still baffled by this situation TBH
    I always thought plugs not working when installed was an old wife's story
    Must say it's great to hear it running again after 18 years
    Good luck everyone
  20. Have a look at my reply in the thread if you are interested
    I get frustrated when people don't let others know the outcome
