998 Sprocket Carrier
Discussion in '748 / 916 / 996 / 998' started by Wooly46, May 21, 2018.
  1. Guys I’ve fitted a quick change sprocket carrier over the winter and I’ve noticed a bit of movement on the cushes! Is this normal or do I have an issue? Everything is torqued as per the book so any help would be appreciated, cheers
  2. Tried to upload a video but with no success!!
  3. I have a bit of movement, it's not changed over a few years.
    Steve
  4. Thanks to the eagled eyed @Chris , I am now taking steps to deal with, what appears to be excessive movement of the sprocket on my o.e.m Carrier on my 1000DS.
    Close inspection of the drive chain shows that the sprockets teeth are rubbing on the links.
    Worth having a close look to see if that's happening to yours.
