1200 Sprocket Nut
Discussion in 'Multistrada' started by Ff6022, Jul 24, 2022.
  1. High guys can someone help regarding rear sprocket and wheel nuts. Anyone know what torque they are? And are they both normal thread (as in not reverse thread).
  2. They are normal thread and you generally need an impact wrench to remove them. (A GOOD impact wrench) I believe the factory setting is 230nM.
  3. Sprocket FT and threadllock and wheel FFT.
  4. I removed the wheel nut last night with a breaker bar but having a tough time with the Sprocket side today. Hence the question. Was worried I was winding it on rather than off. But they are both 230nm? Thought sprocket side was lower but thanks for clearing that up. Cheers
  5. Ah. You said sprocket nuts, but meant axle. Don't put threadlock on axle nut.
  6. Got it off. Took a new purchase of an impact wrench. But I like tools and it’s off now.
