St2 944 Ngk Plugs
Discussion in 'Sport Touring' started by Bob T, Nov 26, 2014.
  1. Thought that I should get some spark plugs as I am not sure how long the fitted ones have been in there. Here is the question, which NGK plugs are correct?
    My French bike catalogue tells me that I should use NGK DCPR8E, yet NGK Partfinder says use DCR9EIX. I know that 8 and 9 are the heat ranges. The handbook tells me to use Champion plugs, but they are not readily available around here.
  2. You need 9's in there. My regular service plug is the DCPR9E for the ST2. Works just fine without forking out on iridiums
