St3 With St4s Running Gear
Discussion in 'Builds & Projects' started by Simon Snowdon, Mar 13, 2020.
  1. Hi there, can anyone tell me if a 2005 ST3 will be able to be fitted with the forks, wheels, swinging arm and rear shock from a 2001 ST4S please?
    Thanks
  2. The wheels, swinging arm and rear shock will fit but the ST4s forks are shorter. You would need to use the ST4 yokes as well.
  3. Thanks, that should be ok because I'm picking up the ST4S complete, the engine has blown.
  4. You will probably have to use the ST4s handlebars as well. The ST3 bars are a clip-on style fitted to the fork leg below the yoke, the ST4 bars bolt to the top yoke.
