St4 Pannier Rack Removaladvice Pls.
Discussion in 'Sport Touring' started by Harlequin, Feb 15, 2019.
  1. Hello St4’ers,
    I am removing the pannier racks, and relocating indicators to the tail tidy.
    One question though. Does the exhaust hanger relocate from the pannier rack to the rear footpeg assembly? Or does it need a separate hanger?
    If it moves to the rear footpeg assembly, then the exhaust has to rise by 30/40mm.
    Appreciate your advice.
    Mike
  2. There are 2 height settings for the exhaust, with pannier racks fitted you have to use the lower setting, when the pannier racks are removed you can use either lower (for passenger foot clearance) or higher (sportier setting).
    When you take the black painted rack off you should be left with a silver painted hanger assembly with 2 holes.
    Hope that makes sense?
  3. Thanks Harry,
    Can you use the same fixings do you know?
    Mike
  4. I think they are the same ones, but not sure as mine were dealer fitted?
  5. I took my pannier racks off last week. Really straightforward and yes; they use the original fixings.
  6. Cheers, took mine off also a d all was good.
    Looks so much better without them, and with the exhausts a bit higher imho.
