Hi guys hope you ate all doing well, .... I am currently in the middle of re wiring my naked st4 2002, I am struggling to find any info for st4 as in wiring schematics just st2, which on first glance appears to be the same, but now nearly finished, found side stand and red ignition light are not on there, I have figured out side stand wiring, but does anyone have wiring diagram for the blue/white, green/black wires from red light,? Thanks guys and gals,
This link may be better. Diagram is at end and is in pdf, so you can zoom in https://ownersmanuals2.com/d/69534
@chrisw has posted all of the good stuff you'll need above .... [ as always ] I've got my 2000 ST4 stripped down right now , so if you need any further wiring info for example , how the main harness or sub-looms are dressed in to the frame .... .... feel free to post back here , or send me a PM .
I have stripped my st4 and done away with connection plugs etc as naked, nearly finished found 3 phase to regulator over heated needs re terminating, but found blue white, black green not on wiring diagram must be unused
There is no side stand or ignition on light on the ST series. 3 is the Neutral light, 4 the fuel warning light, 5 the indicators tell tale and 7 the high beam warning. The other red window is the ignition on light on other models but is not used on the STs.
