St4 Wont Start?
Discussion in 'Builds & Projects' started by Ant Eastwood, Sep 20, 2017.
  1. Another problem, sorry. The bike has not run in over 4yrs. Just had New belts,oil, cleaned tank, new filter and fuel but won't start!!! Fuel pump buzzing so ok. But nothing, not firing
  2. Spark at the plugs? Plugs wet to show fuel? Is it turning over on the button?
    You may need to replace the relays on the bike as they may be stuck closed. They're only a few quid and always worth changing regardless if you don't know the service history (or they've never been done!).
  3. turning over ok
  4. will it need re keycoding?
  5. 4 = no immo
    4S = immo
  6. ok no spark.
    there are 2 relays under seat unit. 1 clicks when you turn ignition on, ther other nothing?
  7. 4S
  8. Full tale? You got a chipped key? Trying to bypass ignition?
  9. i have 3 keys including the red 1 but not sure if thats the problem# but bike has not run in over 4yrs. The immobilizer light goes out when you turn over the engine
  10. She's a runner ye ha!!!!!!! side stand cable..
  11. Good to hear it was something simple. I hope you aren't going to lay it up for another 4 years now. :D
