ST4S Ohlins Shock Spring Change HOW HELP PLEASE!
Discussion in 'Technical Help' started by Ducati888, Mar 3, 2013.
  1. Help!
    Without resorting to spring compressors how do you change the spring off the DU0150 with the remote preload etc etc.
    Normally you can back off the preload nuts and get the C washer out from the bottom to change them, but this has a pin that I don't want to destroy on removal so can't seem to get the normal slackness required.
    Ta.
  2. Is Liz feeding you too well then?
    Give Revs Racing a ring. They are Ohlins service agents & genuinely helpful. Ask for John or Nick.
    Revs Suspension Services
  3. You might have answered you've answered your own question, without spring compressors, or the proper suspension jig, I can't see how you could do it?
  4. Sounds like I did answer my own question, I have been offered a swap service by Bill Waddington.
    Thanks chaps
    (Bigred it's a softer spring you cheeky git!)
