I recently fitted a Quad Lock Wireless Charging Head on my SF V4S directly to the batter (not switched). However, a strange issue arose, the starter motor will not turnover when the phone is on the charger but will do so if removed. I can refit the phone on the charger after the bike has started without problem. Is the ECU sensing a load and prohibiting the starter from enacting? Thanks, Ian
Not come across it before, but there may be interference from the phone that's affecting the antenna reading the key code and not disabling the immobaliser??
Yes, but the proximity of the phone on the charger mount may effect the antenna. Once the bike is started, it's not looking for the key signal any longer.
I have the charging mount on my multi, but I power it from the rear USB which is ignition live & my phone can be on the charger charging when I start the bike no problem
