Hi mate, I've just ordered some I'll give you a bell when they arrive and it will be fresh in my mind. Cheers
No worries, i have the workshop manual whats your email ill ping it over, No special tools required maybe a blow torch to get the bottom sleeve off but never had an issue it may not need replacing, Drop forks and triples out top bearing sits in frame collar and the lower sits on the sleeve of the triple stem, Can run you through it all the same
