Steering Stem Removal
Discussion in 'Technical Help' started by Enoch, Jan 12, 2021.
  1. Does anyone know how I can get the stem out of the bottom triple clamp on an XDiavel?
    I can’t tell if it’s screwed in or pressed in.
  2. On other Ducatis it is pressed in, I'd think the Diavel is the same. Is it wise to remove it?
  3. Thanks for that..
    It’s a second hand bottom yoke that I want powder coating. On trying to get the bottom race off I caught the stem with a cutting disc and put a couple of nicks in. I’m sure it’ll be fine with a new bearing set, but if the stem comes out easy enough, I’d like to put a blob of weld in the nicks, and turn it back down in my lathe... If it won’t come out easy I’ll live with it.
