Sticky Throttle Cable
Discussion in 'Streetfighter' started by Diver, Jul 29, 2017.
  1. anyone else noticed when they turn the handlebars fully left the throttle sticks open?
    Dealer noticed this on my 2nd service also shortly after I removed headlight to put on a DP screen and the cable gets pretty worn and damage behind there
  2. Cable routing. Check fast idle(choke) cable also. It could be that.
  3. yeah do me a favour on the RHS of the bike the cable on mine seems low, all the other cables go behind but above the air intake scoop except the throttle cable, could you check to see if yours are the same please
  4. Evening
    one issue i have had before not on an SF is the one cable was over tightened and would not return correctly
    might be worth a check
