1200 Sticky Throttle
Discussion in 'Multistrada' started by Carr01, Apr 17, 2016.
  1. Having a bit of an issue with the throttle. It's sticking open when you use the heated grips option. Fine when cool. I had the recall done in relation to this problem a few months back.
    Any thoughts?
    Thanks Anthony
  2. I'd get them to check their work. Tell them it's done it since the recall.
    #2 JH_1986, Apr 22, 2016
  3. the throttle is connected by two cables to the assembly under the seat. one pushes, other pulls. over time and regularly these 2 should be checked and adjusted. the adjustment nuts are inside a connecting pod on each cable behind the clocks. open, adjust with spanners and check (see manual). removing freeplay is as important as tightness. the cables should be replaced every few years but typically its the adjusters that need sorting.
  4. Thanks for the info. Will take a look at it this weekend.
