Stm Evo Clutch - Locking Tool
Discussion in 'Wanted' started by RickyX, Feb 16, 2020.
  1. I have just bought an STM Evo Clutch off the kind Mr @duke41 (cheers!).
    I have all the tools already for locking a ‘normal” 6 spring 48t clutch hub/basket but I see this won’t work with the Evo hub.
    Anybody got an STM UTL-0020 90mm spring locking tool lying about that they want to sell?
    Or is there a similar tool that can be used?
    cheers,
    R
  2. If you have no luck, get in touch with Russ at Ducati Mondo. He has one he might lend you.
  3. i have the earlier version of this holding tool that im happy to lend you, but postage may be prohibitive (£35ish round trip).
    i have the stm 48 tooth basket tool also.
    fwiw you can get a cheap tool to hold the 48 tooth basket but the main drum is a tougher proposition.
    it can done with the inverted mole grip type universal clutch holding tools and a rattle gun to remove the nut, but slip and you will mark the anodized pressure top plate
  4. Thanks for the offer but I think I have a cheap solution...
    I already have a 48t tool so am ok for the basket.
    I have got a lovely old clutch hub off @duke41 (thanks, it arrived today) which I will cut the posts off. I can then drill 6 holes at the correct spacing in the top of the hub and fit 6 6mm bolts in it to align with the slots in the Evo pressure plate. The bastard hub tool then fits in my standard clutch tool and, hey presto, I can torque the nut as normal! This will all be done with a hacksaw and standard diy drill etc.
    Well...that’s the plan!
  5. Thread closed
