Strange noises
Discussion in 'Technical Help' started by duc daz, Mar 29, 2014.
  1. When I was wheeling my 1198s into the garage this evening,I noticed a strange clunking noise,as if the chain was catching on something.i put the rear paddock stand on and spun the wheel,it got louder.so I pushed the gear lever down and it disappeared,could this be a false nutreal.
  2. Nearly........but no, IMO.........
    A false neutral will usually appear in between the gears from 2nd upwards, 'cos you mis-footed changing up or down (usually up, to make you look a right pr*t).
    Probably what you got today was a slightly mis-footed neutral, IE you didn't quite get it right when you stopped and what you could hear were gear teeth just touching as you wheeled the bike.....
    Fairly common, I reckon........
  3. Thankyou for that:upyeah: Arquebus
  4. Mine does the same ocassionally.........I ignore it......​
  5. its haunted woooooooooo :Nailbiting:
