Streetfighter 848 Sprocket Options
Discussion in 'Streetfighter' started by gregsf848, Sep 2, 2016.
  1. Hi all,
    Ive been thinking about upgrading the gearing on my sf848, but i don't really want to change the chain, but any sprocket opinions and advise would be much appreciated.
    Many thanks
    Greg
  2. Bump,I'd like to know as well
  3. Come on guys there must be someone on here who can offer some input to this thread surely?.
  4. Without changing the chain you a limited to replacing the front drive sprocket -1 tooth, it's a common modification but the smaller sprocket has a shorter life span than the original.
    For reference if you do go down this route, the ride height will be reduced by approx 2.5mm and should be re-set on the tie-rod.
    Hope this helps,
    kev.
  5. Lovely thanks kev for your reply. i may look into changing the chain as well then.
