Stripped Thread In Swingarm 1199
Discussion in 'Technical Help' started by Russell, May 22, 2014.
  1. Hi guys
    I removed my hugger on my 1199 to give it a good clean, upon refitting I stripped one of the threads for one of the hugger bolts.
    Just wondering if anyone knows the bolts size? I'm thinking it's an M6.. Thinking about buying a Helicoil kit to make a repair, but don't want to buy the wrong one
  2. Can't help you but the threads on the s/arm are dire unfortunately
  3. They are pretty poor tbh
  4. Sorry I can't help with the problem, but I just want to say I admire the attitude of someone who can finish their post regarding a stripped thread on their 1199 swing arm with a smiley - I'd would be fuming and / or in tears ;)
    #4 Snips, May 22, 2014
  5. Ha ha, it's only a piece of metal that can be easily fixed. No point stressing about it lol
  6. Either helicoil it, or drill it out and tap it the next size up
  7. I'll defo be heil coiling it. Need to find out the exact size of the bolt so I can get the right insert :)
  8. Is it a german bolt?
  9. Ja
  10. m6 x1
  11. I know some arms have keen-serts or lock-sert inserts fitted as standard.
  12. Ya ze bolt iz German...
    I deserved that haha. I should check my spelling more often :)
  13. OK, so its a bodge but as a temporary (or even permanent measure) you could always carefully flatten the bolt thread, so it gets wider but with squashed threads either 'side'......might be enough to get a grip in the stripped thread and its not as though there is a huge load on it and if you are going to eventually helicoil (personally I would use an insert) it won't matter if the b*ggered thread get a bit more b*ggered.
    #13 Ghost Rider, May 24, 2014
  14. it would be quicker to just use a helicoil than expend time trying out a bodge and you would only have to do the repair once
  15. But some people want to use their bikes while waiting for the appropriate fixings to arrive......
    ...but as I said, I would use riv nuts and buy a kit which includes the hand tool, simply because if one thread has failed, no doubt another will in due course.
  16. already have a selection of helicoil kits, they do get used from time to time
  17. Thread Wizard
  18. Stick a 1/4" UNC in there!
  19. hopefully that was a joke but don't do it, nothing worse than working on a bike bodged together with a mixture of metric unc and whitworth bolts, you need 3 sets of spanners / sockets and most of the time you pick up the wrong tool = more rounded off nuts and bolts
