Is changing a schrader tyre valve on a super Corsa the same as any other? Mine is leaking. I've seen videos for car tyres and assume it's the same. Any links to kits would be appreciated. Thanks
It could be you only need to change the valve mechanism in body of the valve. 2 minute job and then 10 minutes to pump the tyre back up. Andy
This is the issue, it is the core inside the valve. I purchased a core remover from Halfords, but i doesn't have the pull to be able to lift the core out so have another tool on order that should.
I gathered as much, but the core just keeps turning and the tool won't lift it out. Maybe I'm doing it wrong. Just an annoying little thing to do wrong
Once its unscrewed they just fall out. Tighten it back up. Pump up tyre. Unscrew and air press will do the rest.
My god. I'm dumb. I've been doing it with this valve on the bottom. I'll try it up top. Thanks for the advice
