1200 Suspension Upgrade 2012 S Touring
Discussion in 'Multistrada' started by Beef, Oct 11, 2015.
  1. OK, So I have put over 20000miles on my bike and really love it, as I've got more and more familiar with it I have noticed the front pogo ever so slightly.
    I was wondering if the suspension ECU upgrade was worth getting or just play with damping & preload
  2. I got it on my 2010. Fit it for the ride home and it just works. I absolutely caned it home down twisty country lanes and it was fantastic. You can pick up 2nd hand ones cheap enough now so well worth doing.
    Makes the differences between modes very noticeable too. When the missus is on the back, if we hit some bumpy roads it goes into touring and it smooths out all the bumps. Even she knows when I've changed it to touring, just through feel.
    I got mine through eBay but it just happened to be a forum member on here.
  3. The difference is like Day and night. Best £200 I spent on my 2012 s. Andy
  4. I was hesitant about this upgrade aswell, but it really is as good as people say
  5. The ohlins ecu upgrade is defernitly a great improvement, had mine fitted for a couple of years now and love it
    Bear in mind it only alters damping comp/rebound on the front forks, Spring preload is still manual, so check you have the correct preload and suspension sag for your weight too
  6. Definitely worth having. I bought mine a few months ago s/h from someone on here so a bargain too. I would say it has reinvigorated my love of the Multi.
    15 minutes to install but another hour or more to enter all the settings!
    Important to note that the Ohlins SCU has a wider (but coarser) range of damper settings so that:
    4 on OEM = 3 on Ohlins
    8 on OEM = 5 on Ohlins
    12 on OEM = 7 on Ohlins
    18 on OEM = 10 on Ohlins
    22 on OEM = 12 on Ohlins
    26 on OEM = 14 on Ohlins
    32 on OEM (Max) = 17 on Ohlins
  7. Put your gloves on first. You'll get a sore thumb. Bloody settings. Took ages.
  8. I haven't set the sag yet, I did ask about it when I bought the bike but the salesman was clueless when I asked him about sag settings - plus (as I haven't even looked) I was unsure how straightforward it was due to the electrickery or whether you just crack on as per normal suspension?!
    - do the cables that go into the forks need unplugging prior to adjustment etc
  9. Yes unplug the fork connectors 1st then crack on as normal
  10. Thanks, rear as straight forward?
  11. The rear is a adjusted electronically in the suspension settings menu
  12. I was thinking that from everything I had been reading. Thanks again for clarifying.
