Sv4s Headlight Assembly Not Fastened Down?
Discussion in 'Streetfighter' started by Oly, Sep 18, 2021.
  1. Can someone who has an sv4s please check this.
    My headlight assembly is only attached with three rubber grommets , if you pull gently on the headlight assembly it comes adrift and cants forward.
    Surely it should be more secure than this?
  2. This is correct, there are also 2 M8 (IIRC) nuts at the bottom of the unit that hold it in place. You can see them if you look up underneath the light unit from the front. The whole headlight unit is on rubber supports, which I guess are there for damping. To remove the whole unit, just undo and remove the 2 nuts at the bottom and pull the top pins out of the grommets.... simples.
  3. 2 nuts at the bottom secure it.
