Brand new set of 2 bolts Grade 5, 6AL/4V Titanium Bolt M12 x 55mm - fine metric 1.25 pitch pictured next to original, massive weight saving and will never corrode. free p+p to uk £14.....
As long as you don't use cadmium plated washers under their heads, then they will degrade and can break under tensile strain.
as As you see, they are a flanged bolt, no requirement for a washer of any type, all you need for titanium is a decent assembly paste. And if i remember correctly, set at around 40nm. gary0... i,m pretty sure they will fit, but i cant guarantee it. you would have to check
I have a few sets yes kev. Just send your address in a pm and I can lost out on Monday for you. Also have bi hex sprocket nuts, caliper bolts and M8 fork pinch.
