As mentioned else where I'm in the process of fitting some Woodcraft rear sets. So I've also got a replacement brake line, which has involved removing the rear hugger. All the bolts came out save one of the lower mounts which just span round & round. Further investigation shows the threaded insert has come a drift from the rest of the swing arm. Can you get oversize inserts to fit or am I wasting my time
Do you mean the inserts that are in the swingarm which the hugger bolts fit? Aluminium swingarm I assume? Is it the aluminium or the insert that has failed? This might be useful to give you an idea of what is available.............http://www.insertsdirect.com/ Personally, if it is just to hold the hugger on, I would think a well nut would do the trick. AL.
