1299 Tail Tidy Flex/movement
Discussion in 'Panigale' started by Wull, Jan 10, 2019.
  1. How much movement should there be with these?
    Mine has the DP tail tidy fitted so not quite as long as the std tail tidy but it’s longer than the usual run of the mill tail tidy’s that you’d fit as an aftermarket part, and I feel like it’s got too much movement and vibrates too much.
    From looking at it it’s held on via 4 bolts to the bit that the wiring goes through which itself is held in place via 4 screws so if they’re all nipped up tight which they are I can’t see how I can stop it from vibrating as much as it does.
    I do plan on fitting the Evotech tail tidy which I believe will solve the problem as it’s much shorter, but it’s playing on my mind.
