Tar Spots
Discussion in 'Detailing and cleaning' started by panigale66, May 28, 2021.
  1. After doing 1800 miles up in Scotland my exhaust is covered in tar spots anybody got any good tips for removing them?
    cheers Rich
  2. I seem to remember my mother removing road tar from my skinned knees and elbows with butter!! And it worked!!
    Or try WD40 or GT85 with a micro fibre cloth. Good luck...
  3. Was it done on a newly built/just being laid road? Were the contractors there? If so get a claim in to them for a professional detailer to do the job for you.
    I had this issue 2 years ago on a road being laid in Ashton under lyne and though the contractor was based in Birmingham I managed to get it sorted and the bike properly cleaned in 3 weeks. Cost to them was something like £450 if I remember correctly.
  4. That’s some tarmac laying contract if they’ve relaid 1800 miles of road, can’t even repair small potholes round here...;)
    Here is the product we use at work as prep before wrapping vans and cars, stinks mind but works quickly on those little annoying tar spots removes glue residue too.
    https://www.surechemicals.co.uk/industrial-products/cleaning-degreasing-industrial/tar-remover
    I would think that the Autoglym will have an odour added to it as these products generally do these days usually a Citrus odour to make it smell less chemical.
    #5 DucatiScud, May 28, 2021
  5. Still has a vaguely chemical smell, but not strong and doesn't linger.
  6. Baby arse wiping wipes.
    • WTF WTF x 1
  7. Take it to bits and stick it in the dishwasher?
  8. that's the Barnett Formula in action!
    I'd second trying WD40 or equivalent, perhaps White Spirit, T-Cut if used gently, or even Swarfega (seems to be hard to get at present - stuck in Suez Canal perhaps); I don't think the modern orange-based grainy Swarfega would be a risk, again if used gently, because the grains are only corn meal.
  9. WD 40 works a treat. I know from experience after getting covered in the stuff in Morocco (bike not me). A quick squirt, leave a few seconds for it to do its stuff and gently wipe.
  10. autosmart tardis is the go to product in detailing circles
  11. MR Sheen works really well.
    So do these Screenshot_2021-05-29-17-04-56-02_260528048de7f2f358f0056f785be619.jpg
  12. There's plenty of tar removers on the market, they remove glue deposits too...
    Halfrauds?
  13. I’m intrigued as to why you were covered in WD40, were you dipped in tar? ;)
  14. Brillo pads work well, elbow grease helps.
  15. Ah yes. Gramer was never my strong point
  16. Mine either to be honest. Just tickles me some or all of mine have small or huge errors. ;)
  17. Traffic film remover works amazing but can have a very detrimental effect on some coatings.
  18. Ah other's have said, lots of tar and glue removers on the market. I've used Valet Pro, Gyeon and Autosmart. For a one off use I'd go for the small 500ml of the Gyeon stuff. No need for brillo pads or elbow grease or anything like that. The tar spots bond to the surface so these products literally dissolve them, you'll see them starting to run/bleed after a couple of mins (do it in the shade) and then you simply wipe off. Do this on a clean dry bike, but worth cleaning again after or a quick layer of snow foam if you have it to ensure you remove all remaining residue
