Evening all, After some of your expert advice on an aftermarket termi system for my V2. There’s one going off a 1199, I’ve previously seen 1299 systems fit but unsure if the 1199 would? TIA - any advice appreciated!!
The standard 1299 system was bigger, as was the 959 system than the 1199, not sure if this made a difference to the aftermarket ones also. I saw a vid on YouTube of a guy rebuilding a 959 and he had issues with heat shields that were supplied I think for a 1199 so you may have to take a chance. The swing arm etc is the same so you shouldn’t have issues in that regards and the fact that the 1199 ran 3 bolt flange verses wrap clamp doesn’t matter for a full system but would if it was jus slip ons. personally I’d just put slip ons on there
I thought that Termignoni made one for the V2 but apparently not. I asked Termignoni in Italy as to DB levels for their system and they answered that they did not do one for the V2 yet. Apparently the one for the 1199/1299 SHOULD fit but they will not guarantee it! Also as they haven’t made on specifically etc then no up map from them
