749 Top Yoke Pinch Bolt Size?
Discussion in '749 / 999' started by Nostromo, Sep 23, 2018.
  1. The parts list pdf just says screw...
    Cheers
  2. M8 I reckon. Length to suit...around 25 to 30 mm
  3. 30mm
  4. M8x1.25, torque for them is 22 or 23Nm on greased threads, the manual lists the two steering head bolts but does not indicate which one is 22 and which is 23. Bottom bolts are same thread size but torque is listed as 14Nm done up 1-2-1
  5. Thanks for the replys!
