1200 Torque Settings For Bleed Nipple And Banjo On M4 Callipers
Discussion in 'Multistrada' started by cmyers_uk, Dec 21, 2016.
  1. What torque should bleed nipple and Banjo be on Brembo M4 Calipers? Ive hit google up and searched the forum but no joy. Don't want to be my usual ham fisted self and over tighten.
    Regards
    Chris
  2. Use a ring spanner and the palm of your hand. Push it good and tight but don't force.
    #4 Cream_Revenge, Dec 21, 2016
  3. Thanks will use those, i didn't know if the M4 calipers needed different from standard torque settings maybe overthinking it :) let me know if the exhaust is for sale still on the 26th ( pay day :) )
  4. I have an in built , tighter must be better and have broken so many bolts this doesn't work for me , so I have to use a torque wrench :) Cheers though
  5. I used a torque wrench on a bleed nipple and it snapped right off. I think the brake fluid was acting as a slippery agent.
    I used to snap stuff when using a normal socket set as the leverage is the same regardless of the nut size. Use a ring spanner as they are shorter for smaller nuts therefore you can't torque up a smaller nut so high.
    • Useful Useful x 2
  6. Still available. PM sent.
