1299 Torque Specs
Discussion in 'Panigale' started by codyjphoto, Jun 11, 2016.
  1. I am looking for a PDF with Torque specs specific to the 1299.
    I know this is a subject run into the ground but it seems there are no clear instructions to be found.
  2. Have you tried getting the workshop manual, it has a section for torque on the 1199 so presume it's on the 1299. I've attached the pdf here as most of it is probably the same for the 1299 anyhow. If it gets removed then just send me a pm.
  3. Thank you, I am sure those are quite similar to the 1299.
  4. I am having trouble distinguishing the rear wheel pinch bolts torque specs, I believe they're 25 ft lbs. Also, the front wheel torque specs for the actually axle and pinch bolts. Also the specs on the Caliper bolts?
    Thanks in advance. The dealer I bought it from wont return my calls, they also have yet to reimburse me for things they didn't cover after saying they would.
  5. Edit :- I am having trouble distinguishing the rear wheel Hub pinch bolts torque specs, I believe they're 18.5 ft lbs. Also, the front wheel torque specs for the actual axle Nut 46.5 ft lbs and pinch bolts 14 ft lb . Also the specs on the Caliper bolts M10x1.25x60 - 33.5 ft lb? :upyeah:
  6. Thanks a Million sir!
