Torque Values For Water Pump Retaining Bolts Monster 1200
Discussion in 'Technical Help' started by firecat0_0, Sep 21, 2019.
  1. Hi,
    Can anyone advise the correct torque setting for the water pump retaining bolts?
    Cheers
  2. Not sure what bits you are referring to. From the manual;
    Water intake union . M30x1.5 . 25Nm
    Water delivery union . M22x1.5 . 25Nm
    Water pump cover plug . M10 x 1 . 15Nm
    Water pump bearing retaining screw . M6x1 . 10Nm
    If you mean the cover screws, they are M6 and 10Nm.
  3. 9Nm.. One has a copper washer underneath it. Don't miss it out ;) You can help the seal by adding a little threebond to the screw thread on that one as well.
