About to get a tow bar fitted. It's on a 63 plate Focus. Is it worth the extra £100 to get the proper kit that wires to the CANBUS now that it is out of Warranty anyway? CR
Imho yes for a simple hassle factor. Means if you have a light out or something goes wrong it should tell you (or at least it has on the cars I've had, although never a ford)
almost deffo not, mostly because of the extra labour fitting it. you can by an amplifier/brake out relay for about 20-30 squid.
£100 fitted for the proper kit. it's removable one as I have the fancy self-park bollocks. £405 wired to brake lights. £505 with proper CANBUS wiring kit both inc VAT done at home.
Depends what you're towing? If it's a chavavan, give yourself a damn good talking to and sack the idea
