916 Track Day/race Adaptor Loom 748/916-998
Discussion in '748 / 916 / 996 / 998' started by Duke of Stow, Jul 2, 2025.
  1. If you are converting your bike for track or race and want to remove the left bar switch, speedo and lighting wiring I have the solution for you. I make plug and play adaptor looms which do this, so you don't have to butcher the original wiring. There are two versions:
    1. Removes left bar switch, speedo, headlight wiring relay and indicator wiring. Retains ignition switch tacho, oil pressure warning and engine temperature. £145
    2. Same as above but removes the ignition switch. The kill switch is repurposed to turn the bike on and off. £150
    Both 19 pin and 23 pin versions available.
    All looms are made to order using UK manufactured automotive thin wall wire. If you're interested please get in touch.
