1200 DVT Tricolore Sticker Kit
Discussion in 'Multistrada' started by Justatad, May 10, 2020.
  1. Does anyone have the tricolore sticker kit fitted to their multi , I’m attempting to fit the kit today, I’m just looking for some pics on where the line gaps should be , especially the front above the lights, I’ve watched the you tube vids, but they are a bit vague etc
    Thanks
  2. No I haven't, however, having recently fitted some tank side decals from Vulture-Bike, I got in contact with The Image Works for some advice on fitting, even though I wasn't using one of their products. They were really helpful as I was planning on using the 'wet-method' to attach them, something they advised strongly against, which sort of surprised me.
    They said that the V-B decals were made using bubble-free adhesive vinyl, which isn't suited to this approach, suggesting I use a dry method instead, which worked really well for me.
    You probably appreciate this anyway, so apologies if I'm telling you something you already know.
    Good luck with the task........:upyeah:
