Hi I just tried to leave a review on Ducati Manchester. Why is the number of characters limit to such a small number? I kept getting an error telling me I was 250 characters over, ended up giving up as it seems you can only type a couple of words in the Cons section. It is hard to explain pro and cons with no space.
The pros and cons fields are for bullet points only. You can leave a detailed review with the pros and cons. ps. thread moved from Newbies section (where you seem to post every thread) to here. Please check which section you need to post in, in future. Thanks.
I can see where your coming from Just check through the forums and you will see different areas Just pop your question in one of those It will get moved if in the wrong area Takes time for newbies to find their way around Hello and welcome into the mad house by the way Are you red?
I can't see where your coming from at all Just check through the forums and you will see different areas Just pop your question in one of those It will get moved if in the wrong area, or sometimes even if it's in the correct area, it will be moved to the wrong area So you will never find your way around Hello and welcome into the nut house by the way Are you Yellow? :smileys:
It's dead easy........the strap line on the newbies forum says "Hello and welcome. Why not pop in and say hello, tell us where you are from and what you ride". Couldn't be more explicit.
