I have an almost complete Triumph Speed Triple 2012 front end for sale if you are looking for parts for your special build. Parts are from a 2012 bike. Includes: Forks (Straight) 43mm Kayaba Fully adjustable upside down jobbies. 52mm/54mm tops. Pinch Bolts Axle Spacers Front Wheel OEM Brake Discs ABS Disc Brembo Brake Calipers (Black) Brake Pads Bottom yoke & Stem & Bolts Top Yoke (Ignition Barrel removed, so no mucking about with security bolts needed) & Bolts Handle Bar Clamp lowers (No Bolts) Handle Bar Clamp Uppers (No Bolts) 2CT Trye with roughly 4mm tread in the middle Front Hugger in White Front Hugger in Black Carbon Hugger Trim Please note that the handle bar clamps in the images below will not be the ones that are supplied. Im looking for £700 for the lot to go together. Pictures to follow
Im sorry for the poor quality of the pictures. The parts are still fitted to my Street Triple right now and I'm not getting the bent parts straightened until Tuesday, so Im not keen to strip them off until I have either a Buyer or replacements to put on.
