1200 Urban Mode Throttle Response
Discussion in 'Multistrada' started by Ff6022, Oct 2, 2015.
  1. Hello lads. Like title says I do use urban mode sometimes as I like the cushiony smooth suspension but the throttle response pisses me off. Is there a way to improve it without changing another mode that has better throttle response to have suspension settings that match the urban mode?
    Cheers in advance.
  2. had the same problem, you do get use to it after a while but i ended up changing urban mode to 150 LOW and then changing the enduro mode setting to match the default urban mode incase of bad weather.
    hope this helps
  3. Yes, easy just set power setting in Urban to 150 BHP, you can choose low or high...
  4. Fair enough, I will give it a go and see how I get on. Cheers lads
