Hi All Looking for some inspiration for a permanent USB dash solution on a multi 1200S 2011. Have been running a handlebar mounted usb connector wired into the battery which looks pretty crap and I'm always worried I'm going to flatten the battery. Main usage is for RAM mounted iPhone in the dash for sat nav - need permanent power for it unfortunately or the phone lasts 2 minutes. There isn't a hella socket in the dash, think the nearest one is under the seat but has anyone installed something that will isolate when the ignition is off? Any guidance gratefully received - wiring definitely isn't a strength. Was also considering a powered tank bag as an option. Thanks guys, Robbo
I basically did the same as George. Here's my thread: https://www.ducatiforum.co.uk/threads/hella-dash-socket-alternatives.78331/#post-1656217
