Hi All I’ve managed to lay my hands on a pair of Akra slip ons for V4 Panigale second hand…..what do I need to do with up maps etc? cheers
Take it you want the ECU adjusted for the exhaust? Few options main dealer activated Termi up map Brentuning I’ve a full akra system so had it done by dealer at time of fitting, but, even with that I’m looking at the bretuning option for 2 reasons. Firstly it’s more configurable and a better map than the generic akra map which is vanilla. Secondly, the brentuning has a stage 2 map option so you can change quick shifter responce, lower gear rev limit etc… Gets better dyno results too if that’s your thing. https://www.up-map.it/en/t800/ https://brentuningmoto.com/motorcycle/ducati-panigale-v4/
As far as I was aware, the slipons don’t need mapping but at the back of my mind, the fairing lowers might be different. If you look at the Ducati.com web site under accessories, there will be the information you need. Andy
Lower fairings are different. You need an up map, hence them having one from the dealer or when bought new. https://www.v4evo.com/oem-parts/akrapovic-slipons
