V4 Multi Evotech Satvav Mount
Discussion in 'Technical Help' started by hill100, Jun 22, 2022.
  1. If anyone has fitted the evotech satnav mount for a garmin zumo, can you tell me if the screen adjustment can still go to the lowest position. And how would you rate the quality.
  2. I have one fitted, swapped it over from an older Navihalter I had. Screen adjustment is fine, no problem getting it in the lower position. Also it’s much easier to adjust or tighten on the move. One of the issues with the Navihalter was that the fixings got loose with vibration and you needed to be carry very small spanner to retighten them. The Evotech one has nice big adjusters you do by hand if you want to change the angle.
