For Sale V4 S Front Discs And Pads .
Discussion in 'Parts, Accessories & Clothing For Sale' started by Captain, Feb 2, 2026.
  1. Just to add these do also fit other models of Ducati .
    1260 / 1200s / Monster 1200s and 1200 r .
  2. Technical details .
    Brembo brakes are the gold standard for aftermarket brake products.
    Their Serie Oro discs are a very high quality upgrade over OE items, originally designed for the race track, these discs have been improved and refined to become the ideal choice for road or trackday use.
    Technical Details
    Brembo Serie Oro rotors are made from an extensively researched stainless steel with a unique conformation
    This stainless steel blend is designed to transfer braking forces more effectively, whilst improving resistance to thermal and mechanical stress
    10 Bobbin floating design allows for heat expansion and faster cooling whilst keeping the rigidity of the disc
    Serie Oro discs are typically thicker than OE discs to improve heat dissipation and improve performance
    Specifications
    Unique stainless steel blend for the braking rotor
    Anodised aluminium housing
    10 fixing bobbins
    Same diameter as OE discs
    Full range of Brembo pads available seperately
    Perfect to be used as an upgrade over OE discs
    Brake pads should always be replaced when new discs are being fitted.
    This allows the discs and pads to bed in together, improving the lifespan of both products.
