I think the wider 56mm lower yoke is all I need to change, in order to swap my standard 848 forks for Ohlins, as the Ohlins forks are 53mm at the top, same as standard. If someone knows differently, by all means please advise, but assuming that's right, has anyone got a lower 56mm yoke they'd like to sell me? It may well be the case I need a full upper/lower set, stem & axle for compatibility reasons, which if that's the case, let me know. Input welcome! Ideally the lower yoke will have a centre hole into which I can fit an under-yoke paddock stand. I believe the 848 lower yokes to have a hole, however the 1098 and 1198 ones are solid? Anyway, please let me know what you have. Thanks!
