Looking at the front mudguard on 1299 and it looks pretty tight with a tyre warmer on the tyre . ( carbon mudguard ) anyone running warmers and find it’s tight against mudguard ?
It does look tight but you’ll be fine. As bradders says, feed it in with a bit of tension keeping it nice and snug
Tip I picked up from spike edwards video : roll it up as you take it off, put the Velcro by the valve then as you put it back on it’s easier to stretch. When you take them off, it’s also far nearer than just slinging them across the pit floor
Cheers , I’ve tracked about 15 bikes and not had the mudguard so close to the warmer . good to know all the same .
