Warped Disc
Discussion in 'Technical Help' started by cookster, Apr 4, 2019.
  1. Hello gents, I've got a warped disc on my sps is there anything I can do to sort it or is a replacement set required??
    Cheers
  2. Motoliner Kent way may be able to sort it
  3. If it were me and it was the disc that had gone 'Pringle' (technical term), I'd want a fresh set on.
  4. I would assume it depends on the thickness left..if half worn I would rather buy new.
    Had my Aprilia RS250 lower shock mount re-welded by Motoliners, top people :upyeah: can only recommend them.
    http://www.motoliner.com/motorcycle-brake-disc-straightening.php
    Edit: I assume you tried to free the bobbins first?
  5. Given they are full floating cast iron, I’d check bobbins first too :upyeah:
  6. Maidstone Motoliner - brilliant company; damn good work and not overly costly.
  7. I wouldn't say they were half worn but they look like the originals.
  8. If ori, check for cracking around the bobbins. Seen it a few times on race bikes and also seen results of failure :confused::mask:
