Ive got an adjustable relay to fix my flash rate but I cant find the relay anywhere around the fuse box. Does anyone know where it is? The dash LED fix did not work.
Darn it, ive bought the adjustable relay and its meant to be for the 1100 too. Im fed up now so im going back to bulbs.
On the old 2008's there was a setting to change from standard to led wasnt there? (as in on the dash controls) - cant be sure as ive got an evo sp..
Are you holding Button B down for 3 secs after selecting LED? The dash will then show MEM indicating the setting has been saved.
I’m holding the toggle button for 5 seconds and it does say Mem, but it doesn’t work and when I go back into the settings it’s reverted back to lamp. I’ve ordered the resistors to try but also a set of lamp indicators just in case.
