The mounting bolts on my spare 996R footpegs are 65mm centres and the ones from my 888 are 70mm centres. That is assuming you're talking about the mounting brackets..
The end of the 888 footpeg that into the bracket is 25mm wide and the 996R is 21mm wide. The 888 mounting pin and spring appears a lot bigger than the 996R ones. I dare say with some faffing around you could possibly make them fit.
Ive had back surgery in the past( twice) and have no probs other than pain in my left thigh when my legs are in such a high position that the 888 cases, I want to put these adjustable footpegs on that a few manufacturers now make but only MFW list them for the 888, The Gilles and Chinese ones look a load better but are not listed for the 888 but are listed for the 916 etc, Believe it or not but just that little bit extra adjustment is all it take to relieve the pain, Whats your thoughts on this?? Even 30mm ish plate to drop the mounts would do but I don't want to have things looking like a botch up, I should have maybe explained a bit more in depth on what I was up to, Cheers
This type of thing I was thinking http://www.ebay.co.uk/itm/Ducati-88...081386?hash=item1e757c06ea:g:auAAAOSw9OFZNcX3
I've seen those advertised on E-bay, I think they sell some that have a 50mm adjustment. Why not have a word with M&P to clarify that they will fit your bike and if they don't to return them?
Yeh think these are going to be my best bet, They have a set listed that will fit my bike, Don't think I will go to far wrong with these tbh, Thanks again for the help
