Wtd Fork Outer Tubes From Ss 900 Ie Or Complete Forks
Discussion in 'Wanted' started by andrewinuk, Mar 28, 2022.
  1. Need some 500mm long 50/53mm clamp size fork outers for my Desmo Due race bike if anyone has some spares kicking about. Will take complete forks if they are cheap enough :)
    Assuming only SS 900 forks will work, but there may be others with the same outers? SS carby and monster forks are a little too short at ~485mm.
    Any help or leads much appreciated!
    Andrew
    #1 andrewinuk, Mar 28, 2022
  2. Sorry I can't help find you any, but can confirm the 1000SS outers are longer than every other set of that era that I had the pleasure of rebuilding.
    And I do agree that the 900SSie forks should be the same.
    Good luck.
  3. Only 900ss ie bikes have the same outers it seems so search now a little more restricted.....
