Yellow Passivate Zinc Coated Fairing Washers ?
Discussion in 'Supersport (1974-2007)' started by Kevin Tallant, Jul 16, 2019.
  1. Evening all, after giving the 900sl a good clean I appear to have not tighten one of the front fairing bolts & noticed missing after ride today.
    Any body got a lead for buying washer & bolt ? Only ones I can find are in Germany & quite expensive.
  2. Ducati themselves still sell these. I have a rough spare if you struggle
  3. Have emailed moto rapido & will try Ducati tomorrow. Cheers
  4. Its been a while since I have bought them from Ducati but iirc they are a couple of quid each roughly
  5. I think part nr is 84110011c
  6. You are a God ! Been hunting part number, but only get exploded diagrams with no numbers.
  7. Moto Rapido 4 x washers & 2 bolts just over £20
  8. I'll have a handful if it helps with cost
  9. those are what one uses with the 'washers' - The superlight slot screws take the place of the washers - for easy removal of the seat so you can lift the tank and get at the battery/air filter.
  10. I may be interested In a few too
  11. i'll get in touch with them and work out prices
    Phil
